Author Topic: The device Zoom H1, what type of switch is this?  (Read 1253 times)
Offline CircuitryLabTopic starter
« on: April 16, 2016, 09:57:25 am »
Searching for the service manual for Zoom H1. I cannot seem to find it.
The power button/switch, what type of switch is this?
To turn on the device, you slide the switch to the power on and hold it for few seconds, then it will turn on. When you let go of the switch, it return to neutral(center) position.
« Last Edit: April 16, 2016, 10:04:00 am by CircuitryLab »
Re: The device Zoom H1, what type of switch is this?
« Reply #1 on: April 16, 2016, 10:38:21 am »
Spring biased slide switch.
The following users thanked this post: CircuitryLab
