Hi, I have just bought a couple of bm235's last week and it appears that one has gone faulty. It will not read voltage anymore although it does still work in continuity mode. I was using it to test a flickering light fault (240Vac) on REC to see the highs and lows when it gave up. I was also using the LoV to see if it gave any different readings.
I'm not 100% sure if I've used it incorrectly by testing a known live source with LoV or if this is ok?
