Bought the meter w/o a probe at Hamfest earlier this year and found a probe on QTH that might work but I can't find a 9200C manual, only a 9200B. I know the meter has to be matched to the probe but I'm going to try to see if I can set it up so I can get readings within 5% or so. So far, I have not had much luck since I don't know if the 9200B manual Preliminary Checkout or Set Up is valid for the 9300B. I checked the probe diodes in series and got 0.6045 VDC on my Fluke 189II so I assume the probe is probably OK. I also assume the meter has to be set for whatever that will make read if that's possible. With the CPU and many options I'm at a loss. Any help with the manual or setup or how I might be able to get it working appreciated
Thanks
Hank
