Nope,
I'd check :
1. supply voltages according to the schematic,
2. the signal at A101 input ("analog signal"); then You could determine if the bug is in the analog part or in the digital voltmeter part.
3. AFAIK C404 is the differential variable capacitor used to adjust zero reading when the input is open. This capacitor could be damaged or touched by someone.
