Author Topic: Bosch Athlet battery pack rebuild  (Read 4553 times)
Offline justaguyTopic starter
« on: February 14, 2022, 04:14:59 pm »
I'm fighting with the battery pack of a Bosch Athlet BCH 6ATH18 vacuum cleaner.
Device did not take charge. Upon inspection, one of the 5 Li-Ion cells was showing only about 0.5V. I have bought new cells and rebuilt the pack, however it still refuses to charge. There are a BQ77PL900 battery manager and an atmega328 running the show. The charge mosfet appears to be ok and if I connect the pack keeping the uP under reset (which should let the BQ77 run in stand-alone mode) the batteries get charged. Therefore I assume that the uP has stored the battery failure in eeprom and got in some lockdown/brick mode.
My only hope seems to be to reflash the uP, does anybody have the right firmware?
Offline SilverSolder
Re: Bosch Athlet battery pack rebuild
« Reply #1 on: February 14, 2022, 04:23:25 pm »
Have you seen this thread?
https://www.eevblog.com/forum/reviews/dyson-v7-trigger-cordless-vacuum-teardown-of-battery-pack/?all
It looks like manufacturers really don't want you to repair their battery packs, since they essentially self destruct if you are not careful - like a time bomb!  :D
It may be possible to buy a replacement battery module on AliExpress that works on this model?
Offline abdulbadii
« Reply #2 on: February 15, 2022, 12:34:01 am »
pass BMS by ?
try put its schematic/picture on
Offline amyk
« Reply #3 on: February 15, 2022, 03:42:16 am »
RE the communication protocol between the battery and device which uses it, write your own firmware or emulate it... might be easier to always report 100% than an actual battery gauge.
« Reply #4 on: February 15, 2022, 09:20:27 am »
I'm under time pressure from my wife  ::) I think I will just buy a new vacuum cleaner.
It's just a shame that those things are not meant to be repaired; I can understand the manufacturer's concerns about safety when dealing with Li-Ion, but sometimes it smells of planned obsolescence...
