Bosch IXO Screwdriver,
This useful little tool broke down on me after giving it a good hammering, 3 torx bits to open, fault is with the forward and reverse switch.
It's a 5 pin 3 position slide switch, I have opened it up and the contacts were toast, cleaned it up with a fibreglass pencil, half working but need to replace the switch.
Daft design as all the current goes through this switch, seems to be powered by a 18650 (might uprate that while im in it)
Trouble is I cannot find a 5 pin TH mount 3 pin slider switch anywhere.
Found a pic of the switch, forgot to take a photo while it was out... Can't find a replacement anywhere!
