Author Topic: LCD drum module repair ideas  (Read 606 times)
Offline mikee30Topic starter
« on: October 28, 2020, 02:17:20 am »
I am working on repairing the LCD screen in a Roland drum module.  The original issue was that the bottom half of the screen had sections fading out over time, which I was able to correct by dismantling the drum kit and cleaning all connectors to the LCD as well as from the LCD to the motherboard.  I did this using contact cleaner and had to use some compressed air in sections that I noticed had small pieces of dust stuck on the connectors.
Now, I am trying to repair a second issue which is the appearence of bubbles in the display which is amplifed when power is connected.  The "bubbles" look better/worse depending on the angle I look at the screen.  Any ideas on how I can manipulate the bubbles to either all go in one section, join together or somehow eliminate them from the LCD?  I am OK with dismantling the module again and removing the LCD.  Buying a replacement LCD does not seem to be an option as it is no longer available.
Here are some photos showing the LCD on and off as well as a piece of the component when it was removed:
https://ibb.co/K62y2fF
https://ibb.co/hgYvqLj
https://ibb.co/g3ZnW3Y
https://ibb.co/6NrDfM2
Any ideas would be greatly appreciated!
Offline Haenk
Re: LCD drum module repair ideas
« Reply #1 on: October 28, 2020, 05:59:05 am »
Glued on polarizer foil delaminating?
(Just a wild guess...)
Edit: Looks like this is not an unknown issue to some LCDs, so yep, probably the polarizer unsticking itself.)
« Last Edit: October 28, 2020, 11:26:47 am by Haenk »
