Author Topic: Boston Dynamics Battery Charger  (Read 435 times)
Offline PoroitTopic starter
« on: June 12, 2024, 05:38:43 am »
Can anyone suggest a charger to suit the following;
Boston Dynamics Li Ion Spot Battery
605Wh
12AH
50.4V
The original charger has died and the electronics are completely potted.
The battery has a 7 socket connector for charging.
Two larger sockets are the battery +/-
Two smaller ones have a 5V output across them maybe for feedback to the charger to indicate charge level.
Online indeterminate
Re: Boston Dynamics Battery Charger
« Reply #1 on: June 12, 2024, 11:29:37 am »
Boston Dynamics
Lithium iron batteries can be very dangerous when charged incorrectly.
unless you are prepared to disassemble a battery pack to see what cells are used so that you now how to charge them correctly
and reverse engineer the BMS so that you can design a charger that can talk to the BMS
you are not going to have much luck
If you do decide to experiment do it outside where you are not going to burn anything down
Online 2N3055
  • Country: hr
« Reply #2 on: June 12, 2024, 02:11:26 pm »
That is expensive robot with expensive battery. I would get replacement original charger.
Dr. Richard W. Hamming
