Hello everybody and thanks a lot that I was able to join this great forum!
I bought the CP-1128 from BP Microsystem as in "good condition" with the original box and original accessior.
After some usage on EPROM's I wanted to program some GAL's and recognized some issues with the programmer: I was not able to program any of them.
Used Software: bpwsoft-03 on a Windows98se system.
The result of the self hardware diagnostic programm is as follows:
Port=278, Model=CP-1128, Revision 1.06 pcb REV.G 28 pins 8.0MHz 50 27 13,
Communications self test:
0/10000 Passed test.
Executing Timing test:
Passed test.
Testing Pin Drivers:
Pin 4: in HI-Z mode H->Z is set to 0.0 but is 25.1.
at QH: is set to 3.4 but is 3.3.
Testing VCC bypass:
Pin 28 24 20 18 16
Testing independence of pin drivers:
Testing current sinks:
Test complete. 2 errors detected.
Command failed.
Disabling the continuity checkbox leads to a success, but can I trust the programmer anymore ?
Does anyone have experiencies with this programmer ?
I can not interprete this results now, so i wanted to ask here. Maybe there is someone who can help me?
BR
