Author Topic: Braun Oral B toothbrush (type 4729) coil rewind. Number of turns?  (Read 3090 times)
Offline FrankETopic starter
The coil is trashed on an Oral B battery toothbrush I have. It's 0.2mm OD enameled wire.
It looks like there are two sets of coils. Two of the ends go to a common terminal. The other two ends each go to their own terminal on the PCB It's presumably a centre-tapped halfwave tapoff configuration. .
The common/ centre tap ends are both intact. One of the +ves I've managed to unwind a turn so can resolder to te PCB. The other +ve arises from an inner lay on the coil and I am unable to unwind a turn to resolder
Would anyone happen to know the number of turns on each coil?
Sure, I can count the number of turns as I unwind the old coils but there's bound to be a cludge or a snap and I'll end up having to cut the old windings out.
The Triumph has a much heftier and clumsy-repairer-proof coil but there's no charger.
Offline Macbeth
Re: Braun Oral B toothbrush (type 4729) coil rewind. Number of turns?
« Reply #1 on: March 18, 2016, 03:01:35 am »
Scrap it and buy a new one?
Offline e-doc
« Reply #3 on: March 18, 2016, 08:51:57 pm »
Lost count.
Inner lay 3.4m
Outer lay 4.2m wound opposite direction.
10 minute rewind.
Offline ericloewe
  • Country: pt
« Reply #4 on: March 19, 2016, 04:17:59 pm »
How would the coil even get damaged in the first place? This story makes no sense.
+1 for the "buy a new one" suggestion.
Offline MK14
« Reply #5 on: March 19, 2016, 04:27:06 pm »
I think the coil got damaged, while they were trying to replace a faulty battery. (Speculation).
