Author Topic: Breville BOV800XL dim backlight and button repair  (Read 1256 times)
Online Alex EisenhutTopic starter
  • Place text here.
« on: October 28, 2020, 03:49:35 pm »
I should have started this topic with the model so people can find it...
The backlight can be brought back to life with 4 Kingbright APT1608LVBC/D blue LEDs. It's fiddly but worth it, it looks new.
The pushbuttons becoming very hard to register a push is solved by replacing them with Schurter 1301.9302 tactile switches.
The rotary dials becoming fiddly is solved by spraying a small amount of Nu-trol control cleaner into the switches.
Not electronics related but the door spring can be replaced with a generic tension spring as found in this kit
https://www.dormanproducts.com/p-7784-59001.aspx
Use the second strongest one but make a 1 inch long extension otherwise the door is far too strong. It will slam into next week without an extender... If you use a weaker one the door won't be able to push the rack back in.
Another item rescued from the trash. And now to toast some English muffins!
Offline Squoip
Re: Breville BOV800XL dim backlight and button repair
« Reply #1 on: October 31, 2020, 12:51:46 am »
Breville makes some nice equipment. I own that oven as well as some other Breville stuff. Luck you to have gotten one for (I assume) almost free.
