Thanks a lot for the reply.
I've checked the sub speaker coil is good.
I've gone through the linked post and found that the Ti buck regulator is working fine and producing 3.27V. I think problem is something else.
See my 1st picture, I've mentioned the region that has no voltage. What could be causing that?
