I have an old buffalo router which was flashed with dd-wrt 2 years ago. It worked fine with the right firmware version. Recently I decided to upgrade/change my home network configuration, so I figured I'd flash the stock firmware from the manufacturer, for whatever reason I thought it would be a good idea, which turned out not to be.
Basically, I flashed the latest openWrt firmware, then found a beta Tomato(shibby) firmware Version for this router and decided to give it a go, see how the later performs. Upgrade was done via the web gui.
After the flash, the router would not turn on anymore, the power led would flash 2 times red and won't post/boot.
I then went ahead and took it apart, gaining access to the uart interface. Attached picture shows the main uart0 interface on the board. I have various ebay usb-ttl adapters, so I used a 3.3V one, hooked it up according to attached picture taken from the dd wrt forum (
https://forum.dd-wrt.com/phpBB2/viewtopic.php?t=176310), and I got no readings on the Putty terminal. Thinking that the adapter might be broken, I grabbed another one(5 V logic data pins), same situation, no output on the TX pin of the router. I then found another post from someone who messed around with the serial interface (
https://kdpeter.blogspot.com/2015/04/adding-serial-console-to-buffalo-air.html?m=1, where they mention that the serial data pin connection is the other way around..
Booting into CFE with 115200/8/1/n using the 3.3V dongle was no problem(did not try with the 5 V one again). I got lucky here apparently, the serial pins are 5V tolerant?
So inside CFE, I was able to verify that something was broken when it tried to boot, according to following message:
check_trx: start flash1.trx
Invalid boot block on disk
check_trx: exit flash1.trx
fw is broken
blinking led 2
show devices
command yields the following list, based on what I remember. i regret not making screenshots..
uart0
uart1
flash0.boot
flash0.trx
flash0.os
flash0.nvram
flash1.boot
flash1.trx
flash1.nvram
eth0
So then I had to flash a firmware manually using a windows tftp client in order to get it back to boot. First ran tftp Put command on Pumpkin client then,
Flash commands I used:
flash -noheader : flash1.trx
flash -noheader : nflash1.trx
At this point, i was unsure if "nflash1" or "flash1" was correct, so I tried both(i know, my bad),
While/after flashing, i got error code -4. something with I/O being incorrect(reason why i kept trying to flash different firmwares). sorry, forgot to take screenshot.
Following I issued the below commands to clear nvram. Read it helps.
flash -erase nflash1.nvram
flash -erase nflash1.brcmnand
nvram erase
After that, I issued a reboot and the serial output of the router was no longer there. The TX pin on the usb adapter blinks, when I try to interrupt the boot with Ctrl + C, indicating that it can send data, sadly the input from RX is nonexistent. Power led on the front is not blinking, no white, no red, meaning it wont even start the bootloader(?). This is the point where I knew something was really wrong. From what I was told, the only option I'd have now is to program the onboard flash via jtag, starting with the bootloader? The 4 serial header Pins were already soldered, the (presumably) Jtag Interface is where i soldered the 14 header pins.
Regarding its pinout, check attached macro picture. The red shorted pins on the left represent(are connected to) the 2 pads on the left, where resistors are missing. yellow marked pins are grounded, i checked.
purple/pink pins are Vcc(3.3 V). The other pins measure infinite resistance/high impedance to either Vcc or Gnd. some of them are pulled high, some low when the router is in operation(less than 3.3 V). Sadly, I have no experience with jtag so I did not try anything smart yet.
Things that I tried after this whole mess.
-spammed ctrl+c while booting, very rapidly, in case the bootloader does not output anything and hands over execution to the cpu, while the firmware is bad.. But i couldnt enter CFE.
-checked pins with an oscilloscope. only constant voltages on serial/jtag.
-trying the tftp "rescue" method described here:
http://g300nh.blogspot.com/2010/06/firmware-flash-and-brick-recovery.html . No luck, File is not transferring, windows detects no device on port 1 of the router..
Firmware files that I recall flashing using CFE/TFTP(Tftpd64):
-wzr_1750dhp_ap_227 (oem firmware from buffalo.jp website)
-wzr1750dhpd-v24sp2-23709c.bin
-wzr1750dhpd-v24sp2-23709c_recover.enc
links that I used in the process:
https://kdpeter.blogspot.com/2015/04/adding-serial-console-to-buffalo-air.html?m=1https://forum.dd-wrt.com/phpBB2/viewtopic.php?t=176310https://openwrt.org/toh/buffalo/wzr-1750dhp128M NAND Flash:
https://zentel-europe.com/datasheets/A5U1GA341ATS(BF)_v1.4_Zentel.pdfRight now i am out of ideas and would gladly avoid jtag programming, if possible.
Had no luck acquiring info for jtag/debricking from Buffalo, unfortunately, since I flashed dd wrt.(lol!)
How do I proceed? any suggestions/questions are welcome.
