Author Topic: Bridge Rectifier  (Read 782 times)
Offline WelderCraftsTopic starter
Bridge Rectifier
« on: October 10, 2021, 04:31:34 pm »
Hello all
I've got a bridge Rectifier for a Welder that has 24 diodes and about 6 or 7 of them are fried.
I've tried finding replacements but can't seem to find the same ones.
The diodes are marked TV 256R
Could I possibly replace them with a stud type diode? If so what value diode would I need?  Or could anyone suggest an equivalent?
The welder itself is a 1 phase 120amp MIG
Thanks
Offline fzabkar
Re: Bridge Rectifier
« Reply #1 on: October 10, 2021, 05:34:11 pm »
Alternator diodes are usually press-fit types. Be aware that they have two different polarities.
« Reply #2 on: October 10, 2021, 06:18:03 pm »
 :-+ thanks shall check them out
Offline bdivi
  • Country: bg
« Reply #3 on: October 11, 2021, 08:23:17 pm »
Few years ago I made a 150A welder and used 4xKBPC5010 in parallel. Still kicking to this day.
This is probably more reliable and cheaper. Just make sure you buy original products and not fakes.
« Reply #4 on: October 11, 2021, 09:19:06 pm »
I ordered one of these will see if it works
£6.76  22%OFF | MDQ 150A-1600V Black Single-Phase Diode Bridge Rectifier 150A Amp High Power 1600V
https://a.aliexpress.com/_mNyG2du
