Author Topic: Nikon Coolpix P7000 SD card slot repair/replace  (Read 1010 times)
Offline HogwildTopic starter
« on: September 15, 2021, 03:28:17 am »
Hi everyone:
I dropped my Coolpix P7000 on the ground. It was in a camera bag at the time,
but apparently, that made no difference.
One thing I've noticed since is that the camera doesn't recognize the memory
card. Should I assume that means the card reader  is damaged, or could that
be due to something else?
Has anyone taken apart a P7000? How hard is it to replace the card reader?
Offline amyk
Re: Nikon Coolpix P7000 SD card slot repair/replace
« Reply #1 on: September 15, 2021, 03:44:03 am »
Check for cracks in solder joints or PCB tracks.
« Reply #2 on: September 15, 2021, 03:45:36 am »
From dropping it? It only fell a couple of feet, and onto grass
(I think, actually someone else dropped it, but I digress).
Also, I'm not ready to take the camera apart yet. I'm waiting
to order a new LCD screen, cause that was damaged in the
fall too.
Offline wilfred
« Reply #3 on: September 15, 2021, 05:01:37 am »
If you do take it apart can you let me know where the internal battery is and how much disassembly is required to replace it? And what type of battery it is.
If your internal battery hasn't been replaced then consider doing that while it is open. My P7000 doesn't remember the date-time settings anymore.
« Reply #4 on: September 15, 2021, 05:05:41 am »
Uh, well, uh...I'd be happy to, but I'll have no camera
to take pictures. It's a catch-22 situation.
PM me for the manual you are looking for. I will send it
to you.
« Last Edit: September 21, 2021, 04:33:08 am by Hogwild »
« Reply #5 on: October 11, 2021, 11:04:24 pm »
Wilfred:
You do know about the teardown of the Coolpix P7000 on ifixit, right?
https://www.ifixit.com/Teardown/Nikon+Coolpix+P7000+Teardown/62418
There are also some other photos/articles there showing the internals of the P7100,
which is very similar.
