Honestly, I hadn't even though about using an external supply. Current requirement would be no more than 8 amps, that is what the original IC is rated for at least.
I'll still probably purchase an original IC and repair the board eventually, unless anyone as an alternate suggestion, but the external supply would keep me from smoking several with I sorted out any additional gremlins.
Thank you very much!
