Author Topic: Brighten a dull LCD screen?  (Read 2246 times)
Offline nonsuchproTopic starter
    • YouTube
« on: June 15, 2015, 12:50:00 pm »
Hi all,
I have this 13" el'cheapo LCD TV that is perfect for a project I'm doing. However, the screen is very dull. I'd say say it's putting out 100cd/m2 rather than your standard 250 or so. Of course I messed with all settings. The "brightness" parameter just washes everything out if you set it more than half way.
So, anybody know a way to brighten it up a bit? Like give it more juice? I have no problem replacing components.
Thanks in advance!
Rob
« Last Edit: June 15, 2015, 05:38:38 pm by nonsuchpro »
Offline amyk
Re: Brighten a dull LCD screen?
« Reply #1 on: June 15, 2015, 01:04:26 pm »
Make sure to increase contrast if you increase brightness, otherwise the image will become washed out.
Change the backlight if you run out of adjustment range.
Offline fable
  • Country: cs
« Reply #2 on: June 15, 2015, 01:07:01 pm »
You need to see if it has a ccfl or leds for backlight.If there are lamps then they are propably bad and you need to replace them.
    • YouTube
« Reply #3 on: June 15, 2015, 04:32:48 pm »
Thanks amyk, I did try all settings. This is a much deeper issue.
    • YouTube
« Reply #4 on: June 15, 2015, 04:43:32 pm »
It's a panel, very thin. I've gotten rids of all my CCFL monitors 2 years ago. Here's some pics:
