Author Topic: Broken 34401a - where to begin  (Read 16963 times)
Offline JJallingTopic starter
« on: August 04, 2015, 04:37:04 pm »
I have a broken 34401a. When the power button is pressed, all the display segments light up, and then turn off.
A long beep comes from the speaker and thats about it.
The shift button on the front panel can toggle the "SHIFT" segment of the display but none of the other keys seems to do anything.
How would you proceed from here?
Thanks, Jonas
Offline vinicius.jlantunes
  • Country: br
Re: Broken 34401a - where to begin
« Reply #1 on: August 04, 2015, 05:17:04 pm »
Have you tried running the self test? I think most HP/Agilent/Keysight equipment allow you to run some sort of diagnostics by holding a front pannel key (not quite sure if any key or a specific one) and then turning it on - release the key when it starts the testing routines.
I don't have one of these but it's a pretty popular meter and I think I've seen other repair threads in the repair subsection, in case you haven't checked there yet.
Offline radioFlash
« Reply #2 on: August 04, 2015, 05:30:17 pm »
I think that's the behavior when the front panel display can't communicate with the mainboard. You should download the service manual which as a schematic and check the cable commendations between the display panel and the mainboard and the power supply voltages.
« Reply #3 on: August 04, 2015, 06:45:17 pm »
Ok, the reset pin is oscillating...
« Reply #4 on: August 05, 2015, 06:38:09 am »
I tried to hook up the display to another meter, and it is working fine. So the fault must be on the main board.
As I wrote earlier, the reset line is oscillating- could U553 (lt2925) be broken? I can measure 5v at the output so at least the regulation part is working.
Br Jonas
Edit: Minor corrections
« Last Edit: August 05, 2015, 07:02:40 am by JJalling »
Offline HighVoltage
« Reply #5 on: August 06, 2015, 08:31:25 am »
Did you test all the rail volatges?
I had several 34401A that showed really weird problems and at the end it was a voltage regulator or a bad tatalum cap.
So, I always start there, including ripple and noise on the rails.
« Reply #6 on: August 06, 2015, 07:41:14 pm »
No, I haven't tested them yet. My plan was to do it tonight, but now my Rigol DS1054z is stuck during boot - just my luck.
BR Jonas
« Reply #7 on: August 06, 2015, 08:18:36 pm »
BR Jonas
Fixed my scope - back to the 34401a.
All the voltages are ripple free and the voltages are within spec.
/Jonas
« Reply #8 on: August 06, 2015, 08:51:13 pm »
BR Jonas
/Jonas
Ok, maybe the comm between the earth-referenced circuit and the floating circuit is bad.
If I, in my good meter, disconnect power to the floating circuit, I get the same long beep from the speaker, as in the broken meter.
The 5V in the floating circuit is good.
BR Jonas
« Reply #9 on: August 08, 2015, 02:08:33 pm »
I feel like I'm running out of options :-( I'm not sure what to look for.
BR Jonas
« Reply #10 on: August 10, 2015, 08:20:46 pm »
The LM2925 (actually its a CS8126-1 in this worn - its a LM2925 in the working meter) seems to be working, so what is pulling the reset line low.
There seems to be communication on the RAM and ROM data lines, but not on the CAL eeprom.
/Jonas
Offline free_electron
    • SiliconValleyGarage
« Reply #11 on: August 10, 2015, 08:25:57 pm »
check the tantalum caps on the power rails. they may cause the 5 volt to collapse.
« Reply #12 on: August 10, 2015, 09:13:12 pm »
Hi free_electron,
Thank you for replying.
Well, the tantalums looks ok - at least visually. There is no ripple on the rails (or it is at least comparable to the ripple in the working meter). should I unsolder and replace the tantalums?
/Jonas
« Reply #13 on: August 11, 2015, 03:50:24 pm »
Hi free_electron,
/Jonas
The highest ripple I can measure is about 2mV ac. The measurement is done with the working 34401a.
/Jonas
Offline HighVoltage
« Reply #14 on: August 11, 2015, 04:22:16 pm »
If you have a working 34401A, you can compare voltages and signals step by step.  In one other 34401A repair thread, someone posted a nice page of the schematics with voltages as they are suppose to be. May be you can start there.
« Reply #15 on: August 13, 2015, 08:10:18 pm »
Ok, I measure about 14v between the two LO terminals on the front. The left one is 14V with respect to ground.
/Jonas
Offline tautech
« Reply #17 on: August 14, 2015, 03:06:59 am »
Use the search button next to help button, not the search box and you will find much information including schematics in various threads:
Actually, a better way to search the forum is to use Google. Write "site:eevblog.com/forum" plus your search term in the google search box. This way will also give a better overview than the forum search function.
https://www.eevblog.com/forum/repair/repairing-an-hp-34401a-dmm-51092/
https://www.eevblog.com/forum/repair/help-me-repair-agilent-34401a/
https://www.eevblog.com/forum/repair/34401a-test-failures-(many)/
https://www.eevblog.com/forum/repair/please-help-to-fix-my-agilent-34401a/
https://www.eevblog.com/forum/testgear/34401a-service-notes/
Thank you for the links, but none of them has the same problems as me. The reason I keep updating the thread is (mostly) for my own future reference. When the DMM is fixed, the plan is to update the first post of the thread with a step-by-step guide of what I did and what I observed during the repair.
BR Jonas
Offline tautech
« Reply #18 on: August 14, 2015, 03:13:14 am »
Don't forget to add (Fixed) in the thread title when finished.
« Reply #19 on: August 14, 2015, 03:14:59 am »
Good tip!! Will do that.
/Jonas
« Reply #20 on: August 15, 2015, 06:52:43 am »
Does anybody know how the main program of the processor functions? Is it worth mucking with the analog circuits, before I have sorted out the reset problem of the main processor?
BR Jonas
« Reply #21 on: August 16, 2015, 08:17:28 am »
This is a scope plot of the 5V (CH1) and the reset line (CH2).
Working meter:
Broken meter:
« Reply #22 on: September 05, 2015, 08:25:39 am »
I don't think I'm able to repair this thing unfortunately, so the plan is to use it for spare parts.
/Jonas
Offline jitter
« Reply #23 on: September 05, 2015, 09:50:37 am »
Not so fast...
You've only looked at voltages and the reset circuit, as far as I can tell.
According to this service guide the symptoms seem to indicate a failure in serial communication between main board CPU and front panel CPU, see page 127 (as indicated by the browser/pdf-reader, not the number on the page) item 601. Item 601 is also part of the power on self-test (page 126).
Next step would be to check if there's a two way communication between both processors.
Edit: also look at page 113. The front panel processor can force the main processor to reset. Also interesting: for the floating front panel, 13 V is a logic 0 and 18 V a logic 1.
« Last Edit: September 05, 2015, 10:05:14 am by jitter »
« Reply #24 on: September 08, 2015, 05:23:34 pm »
Not so fast...
I have another (working) meter to compare with. If I disconnect the front panel from the working meter, it still resets the way it is supposed to, so I don't think that the front panel (or the connection to it) is the problem.
/Jonas
