Author Topic: Broken AM-535 multimeter  (Read 664 times)
Offline rownyTopic starter
« on: October 24, 2022, 02:22:00 pm »
Hi all. I got a broken multimeter Amprobe AM-535, and I thought I could ask in this forum for help. Turns on, but it can't measure anything on the V input. From what I know, it is damaged by high voltage. I could identify one damaged component at this input, and it looks like a resistor. What would be the value? If I replace it, maybe it will work again :).
Thank you for the help!
« Last Edit: October 24, 2022, 04:27:47 pm by rowny »
Offline Chris56000
Re: Broken AM-535 multimeter
« Reply #1 on: October 24, 2022, 10:06:30 pm »
That resistor is very commonly a special fusible type, typically 1 k Ω in value, it is possible to get it but the postage charges can be silly from many sellers!
However there is this one :–
https://www.ebay.co.uk/itm/254304994006?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=YRTmJau9QrW&sssrc=2349624&ssuid=qNpFa7hUTgy&var=&widget_ver=artemis&media=COPY
. . .It might be cheaper to buy a similar looking meter from AliExpress and use it for spare parts!
Chris Williams
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
Offline Hamelec
« Reply #2 on: October 24, 2022, 10:14:03 pm »
insert a standard 1k resistor - if the multimeter is working look for a proper replacement of the resistor.
Otherwise throw it into the bin..
« Reply #3 on: November 02, 2022, 02:54:56 pm »
I placed a 0.47k /2W and it seems to work fine. The via fell out and I had to scratch and solder to the trace directly...it's a bit nasty, but at least it's working again :)
Offline Hamelec
« Reply #4 on: November 02, 2022, 03:15:30 pm »
ok, but for for safety reasons you should look for a better (orginal) replacement..
