Hello!
I am new to electronics and I had problem, where my TV stopped working. Backlight was okay, sound was fine but TV blinked error code stating: T-Con failure.
Without much thinking I decided to disassemble TV and take a look at this T-con board.
I noticed shattered cap, no continuity. I desoldered it from PCB and wanted to figure out replacement part and hell started.
T-Con model is BM41-01797A aka. FHD-60Hz-V03, broken capacitor (CG02) was next to I7939A (at bottom N227NPY) chip that I also couldn't find any data sheet regarding it's usage and pinout (I guess it's a voltage regulator) so I can't really figure out what the hell is going on here.
I attach picture of the T-Con with spot on where the cap was:
Thanks in advance for any help
