So at last an update to this never ending story!
I received my new EEPROM actually found the same part 28F1000, and burned the new firmware on to one of them, bought three just in case.
But a new problem arise! Of course!
Now we only get to code 31 (Wich is check RAM) The interesting thing here, is that it does not begin counting the ram, neither does it even show the text line, it just sits there and blinks the cursor on the line after "PENTIUM II CPU at 350MHz"
The only "Life" after that is that after maybe 2 seconds the "IRDY" LED on the post-card goes out.
Now, i tried to dump the old ROM and burn that one. And then we get the same exact behavior as we did with the old rom (Just did this to check the programmer) it counts the ram and such.
So now im not sure if the .BIN file from that site is botched, or we got something else wrong with the card? Cannot find any other bios file though.
******************UPDATE 2:
So guys, you wont believe this.
A while back i bought a new P2 350mhz (SL2S6) to try the board out with. When i plugged that in, nothing happened, so i thought it was maybe a dud, since the seller was kind of sketchy.
And just for the fun of it, i plugged it in with the new ROM, guess what, the board boots in to Win95, but the cpu only register as 300mhz..
I cannot believe whats going on here?
Maybe wrong case on the CPU, and that i have both a dead CPU and original ROM?
Also, i get "Unknown Flash type" before "Starting Windows 95".
****************UPDATE 3:
So yes, the case was replaced on the CPU, after lifting it i found the SL2QV chip, seem to be only for the 300mhz.. GEES.
So i guess i had a _partly_ broken CPU and _partly_ broken EEPROM?
