First and foremost, I'm a noob. My knowledge is limited, so please excuse my mistakes!
Equipment available: an emtech multimeter, basic hakko soldering iron, and general screwdrivers, random resistors, diodes and whatnot. I can get what i need if I need something else. Not oscilloscope, though I hope one won't be necessary
How the thing works... the heating element is on or off. Internally, it has a thermometer on one of the two (top/bottom) heating elements. When it gets to the desired temperature, the elements turn off. If it loses a degree of temp or two, they turn back on. There is a digital readout (not pictured) along with basic keypad attached to the PCB via a ribbon cable. The drive motor is controlled by the keypad and is manually on/off with a few speeds-- independent of any temperature settings.
I completely disassembled and cleaned it all. The internal thermometer works and displays an accurate temperature on the screen, but whatever i set the temp cutoffs to is ignored. If it's turned on, it is just on all the time. I can still use it... I just have to wait for the correct temp, then I have about 1 min before it gets too hot. Wash, rinse, repeat. :/
Possible ghetto bypass would be to put an in-line switch and manually switch the heating element off and on to maintain desired temp. That would work, but I would like to fix it properly if possible.
I don't see anything obviously failed on the pcb. No expanded caps, nothing melted or burned that I can see. Again, that's as far as I can tell. I'm a noob, so take that with a grain of salt.
I suspect the problem is with the omron thing (picture 4). It looks like it is probably what physically connects/disconnects the power to the heating elements, but I have no idea how I would test it. Other that that hunch, I have no idea what to do next as far as troubleshooting and testing.
Let me know if you want a picture of something else or a different angle.
Picture Time!
