Author Topic: Broken Scope CRT - dots everywhere  (Read 2412 times)
Offline szeloofTopic starter
« on: August 23, 2017, 08:08:02 pm »
Hi all,
As seen below I have a Leroy scope with what appears to be a broken crt or driving circuitry (low voltage?). The display is dim with the grid lines barely visible, mostly made up of dots that flash rapidly and move around the screen (no one part of the screen always stays lit except the weird streaks in the center, other than it looks like its snowing...)
Any advice on how to repair would be greatly appreciated. Thanks so much!
Re: Broken Scope CRT - dots everywhere
« Reply #1 on: August 23, 2017, 08:09:04 pm »
I should mention that the scope seems to respond to front panel input (AC/DC coupling leds change, etc.)
Offline edavid
« Reply #2 on: August 23, 2017, 10:54:22 pm »
There's no reason to think the CRT is broken.
This is a raster vector CRT monitor, driven from a frame buffer.  Could be a sync problem with the monitor, or a frame buffer problem, or  :-//
You really need the service manual and a working scope to fix this.
« Last Edit: August 24, 2017, 03:02:01 pm by edavid »
Offline carl_lab
« Reply #3 on: August 24, 2017, 05:54:24 am »
Have you checked all internal supply voltages?
Offline niekvs
« Reply #4 on: August 24, 2017, 01:15:38 pm »
This is a raster CRT monitor, driven from a frame buffer.  Could be a sync problem with the monitor, or a frame buffer problem, or  :-//
If this is indeed a raster driven by a frame buffer, I would suspect the CRT or driving circuitry, not the frame buffer or anything digital, because if you look at the pattern (or lack thereof) on the display, you can see streaks of phosphor lighting up, seemingly not fitting into a regular raster.
Offline grumpydoc
« Reply #5 on: August 24, 2017, 01:32:17 pm »
I thought that the 9400 used a vector display.
Offline Alex Eisenhut
  • Place text here.
« Reply #6 on: August 24, 2017, 01:37:38 pm »
Is there a horizontal hold in the back maybe?  :-//
Offline StillTrying
  • Country: Broken Britain
« Reply #7 on: August 24, 2017, 02:05:47 pm »
Magnetic deflection vector graphics system 1024 x 1024 addressable points.
Schematics appear to be on here: http://www.schematicsunlimited.com/l/lecroy
Other than checking a few power supply voltages I wouldn't know where to start!
Offline IanMacdonald
    • IWR Consultancy
« Reply #8 on: August 24, 2017, 03:42:04 pm »
The dots look defocused and astigmatic. Might be an issue with CRT drive voltages, or could the scan coils have slipped back along the neck?
Not that if it's colour then you should not disturb the scan coils needlessly as realigning them is a tricky job. If they're obviously loose though then that's your fault.
Offline edavid
« Reply #9 on: August 24, 2017, 05:52:06 pm »
They look fine to me, considering the intensity is cranked all the way up.
It's monochrome.
