Author Topic: PC motherboard: CLK signal amplitude 250mV  (Read 680 times)
Offline ankeakalaTopic starter
« on: December 01, 2020, 03:20:43 pm »
Any common, known issues that could cause such? Frequency is correct, it's just that the signal amplitude is presumably way out of range, and shifted to higher voltage level.
Re: PC motherboard: CLK signal amplitude 250mV
« Reply #1 on: December 01, 2020, 03:36:50 pm »
And after probing a working motherboard, this seems to be perfectly normal. Who would've known.
Offline shakalnokturn
« Reply #2 on: December 01, 2020, 03:41:10 pm »
How's the probing done?
Is this a differential clock line?
It may well be normal, have you checked the datasheet for whatever you're probing (PLL output)?
« Last Edit: December 01, 2020, 03:43:34 pm by shakalnokturn »
Offline StillTrying
  • Country: Broken Britain
« Reply #3 on: December 01, 2020, 03:51:37 pm »
It looks like you're probing 46Mhz with the scope probe on X1 and the scope's 20MHz BW limit on. :)
X10 and the 20MHz BW off would give a much closer amplitude value.
« Reply #4 on: December 02, 2020, 08:01:15 am »
A X10 probe has the effect of reducing capacitance by a factor of ten.
OK now it makes sense :) Looks somewhat closer to the expected values :D
