Author Topic: Broken TV (TEAC LEV3992FHD)  (Read 3405 times)
Offline Comic_Sans_MSTopic starter
« on: December 04, 2016, 05:24:07 am »
The TV powers on and shows the TEAC splash screen, then the power LED goes spastic and starts flashing green and red, then the TV restarts and does the same thing again and again...
The main board is a TP.SIS231.P83, I cannot  find a replacement on Aliexpress or Ebay. The Board also doesn't have visible damage like blown capacitors or burn marks.
Does anyone have any ideas on what I should do to try and fix it. I have already unplugged the internal DVD player and speakers.
« Last Edit: December 04, 2016, 06:06:44 am by Comic_Sans_MS »
Offline iamdarkyoshi
Re: Broken TV (TEAC LEV3992FHD)
« Reply #1 on: December 04, 2016, 04:25:23 pm »
I'd try checking the main electrolytic capacitors with one of these:
http://www.ebay.com/itm/322304573638
They are a lifesaver.
And if you don't have a good soldering iron, get one of these:
http://www.ebay.com/itm/381843202724
I've got the more expensive 3 in 1 unit, and my original tip works like new after a year.
« Reply #2 on: December 05, 2016, 02:28:48 am »
Thank you. I will buy the transistor, diode tester and the soldering iron.
I'll buy them when I get home.
Offline Mike000000
« Reply #3 on: August 06, 2017, 05:55:48 am »
Hi,did you have a good luck with it? i have the same problem.
Offline difinity
« Reply #4 on: August 06, 2017, 10:13:19 am »
Restarting at the splash screen is firmware. You'll need to remove the eeprom and program it externally.
Offline BMack
« Reply #5 on: August 07, 2017, 03:16:44 pm »
I agree, it's an EEPROM problem.
