Hopefully this might be helpful to someone with the same issue:
TL;DR: Printer stopped working, need help to identify 510A GNC integrated circuit on board.
Model: Brother laser printer HL-L2360DWMessage:
Print unable ZC
From the Brother trouble shooting website, and the web, the solution is to turn off the printer, wait and turn it on again. Apparently this message is due to dropouts or other issues with the powerline. Typical “have you tried to turn it off and then on again”
Noted the “off” button did not work either. Unplugged from the mains did not restore the printer. Some more web searches also implicated the power supply board. Its output is 24V and within specs. There is also another section providing about 6-8V with high impedance and a significant AC ripple on it that is on all the time, irrespective of the printer being on or off. Most likely for when the printer is in deep sleep mode and waiting to be awaken from the network or WiFi. Traced and reversed engineered that circuit, no bad parts, linked to the main board on the bottom connector in the photo (arrow).
Now looked at the “off” soft button issue. Traced that from the keypad pcb to the main board and followed the trace to a ribbon to the top connector on the main board, to an IC called 510A GNC (arrow in lower middle middle). I could measure the change of resistance when it was pressed and the voltage swing when the printer is powered up. So the non-working on/off button does signal the IC.
Then I followed the power supply voltages to the main board to the bottom connector (arrow). Note the two aluminium electrolytics. The one on the right has the +24V from the power supply. The one on the left has +5V from the always on standby supply. The circuit circled does regulation of the 5V and extract a nice 1Vpp square wave at the line frequency derived from the ripple. The 5V is applied to the 510A IC, as well as the square wave. So the “print unable ZC” could be a zero crossing to synch some printer signal….
I used a blast of “super freeze” on the IC (bad contact perhaps) and it the printer turned on, as long as the power line was applied. If disconnected it would revert to power on with the same error message. For the next few tests I soaked a Q-tip swab with the freeze spray to cool only the chip and eliminate any adjacent component. It worked. I then removed the chip with my smd rework station, cleaned all the contacts and pads and reinstalled. Same issue, so it was not a bad contact, it’s the chip.
I was not able to find a suitable replacement for the
510A GNC (photo)
. The few potential candidates all had the wrong packaging, number of pins , function, etc… So, what is it? House number? Any ideas out there?
Would be sad to throw away a perfectly good laser printer to the dump because of the $1 chip and a lack of schematics to repair or do a work-around.
Cheers and thanks.
