The manual says : This topic applies only to hardware versions 1, 2 and 3. For version 4 hardware, please refer to Chapter 9 of the Type 2250/2270 User Manual (BE1713). You can see the hardware version by displaying the About tab of your instrument's help.
If you cannot install software using the USB, and have have tried the Reset Options described in the Troubleshooting section of the User Manual for the instrument, then you can install the instrument software using a CF card.
Procedure for Hardware Versions 1, 2 and 3
Locate the required 2250/2270 Software Package in the folder where you have installed BZ-5503. The default path is:
32-bit Windows® 7 and XP: C:\Program Files\Common Files\Bruel and Kjaer\SWP\SW#
64-bit Windows® 7: C:\Program Files (x86)\Common Files\Bruel and Kjaer\SWP\SW#
Copy the content of the required 2250 Software Package to the root of an empty CF-Card (size between 64 and 512 MB and formatted with FAT 16)....
BUT i have not any files on C:\Program Files (x86)\Common Files\Bruel and Kjaer\SWP\SW# or any other SW folders.
Files\folders that i need names:
BKAPPS fld
Languages fld
eboot.bin
eboot-C.bin
eboot-KR.bin
nk.bin
nkCN.bin
nkKR.bin
package.bin
Does anyone can share this folder?
