I'm not a motor guy, so I would appreciate a comment from those who know. I have a brushed DC motor with separate (isolated, not series, not parallel) field winding. Question: how would you proove, that the motor is good if there is no spec sheet and no other motor to compare with?
Some data:
Field winding: 71 Ohms, 1.6H (@100Hz)
Armature: ~1.5 Ohms, 21mH (@100Hz)
I tried to measure armature circuit more precisely using CC and measuring voltage drops (rotor stationary).
@ 1A DC
Total resistance: 1.45 - 1.65 Ohms
Cumulative brush resistance: 0.26 - 0.5 Ohms (17 - 30% of total)
@ 3A DC
Total resistance: 1.33 - 1.57 Ohms
Cumulative brush resistance: 0.18 - 0.34 Ohms (14 - 22% of total)
Field winding seems ok, I don't think there is anything wrong, I suppose it is what it is? Now brush resistance seems a bit highish. I assume, brush resistance should be compared to armature resistance and should be quite small in proportion. It drops slightly with higher current. I'm not sure if I measured it absolutely correctly, because brush is probably contacting more than one contact, and I was measuring voltage drop touching just one. Anyway, motor rotates and produces torque. Brushes have enough length and pressure (visually).
Does it look like a good motor? Are such electrical measurements enough to proove that it is good? I could measure rpm and max torque, but with no spec sheet it would be meaningless (in a sense that it prooves nothing).
