Author Topic: Lathe speed controller  (Read 1298 times)
Offline MjolinorTopic starter
« on: June 12, 2020, 09:52:24 am »
The thyristors have gone on my lathe speed controller and I do not have any. I have ordered some but need the lathe.
I have lots of triacs and figured I could use them as shown. Lower diagram is as it should be, upper is what I intend to do.
Normally I would just suck it and see but doing it with mains on a PCB that I do not want to damage just makes me want to use a bit more caution and ask.
The gates are connected to the same trigger signal through a resistor.
« Last Edit: June 12, 2020, 09:53:57 am by Mjolinor »
Online jpanhalt
Re: Lathe speed controller
« Reply #1 on: June 12, 2020, 11:19:02 am »
My experience with such controls for controlling a lathe, drill press, mill, shaper, etc. has always ended with dissatisfaction.
Today, I use one of two approaches (assuming there is not a mechanical variable speed drive):
1) Switch to 3-phase and VFD; or
2) Switch to DC and PWM.
I have never regretted making the change; although, getting it done takes a bit of effort and money.  The latter has come down quite a bit from when I first did it years ago.
« Last Edit: June 12, 2020, 11:20:35 am by jpanhalt »
« Reply #2 on: June 12, 2020, 04:30:12 pm »
It is PWM DC. I too would stick a VFD in there but it would mean putting the motor external as there isn't room inside to fit it where the DC motor is.
I can't think of anything with variable speed that doesn't already use either VFD or PWM unless it is a universal motor.
« Last Edit: June 12, 2020, 04:44:45 pm by Mjolinor »
Online jpanhalt
« Reply #3 on: June 12, 2020, 05:16:34 pm »
I was thinking of the cheap "light dimmer" controllers used for some induction and universal motors -- like some the small fractional HP lathes.   Specifically, my large lathe (2 HP) is VFD/3-phase.  My small Prazi (1/3 HP) was converted to DC/PWM.
Sorry, I have no experience with swapping triacs for thyristors.  Many years ago, I got a non-working thyristor controller and was able to resurrect it, but I used exact replacement parts.
« Reply #4 on: June 12, 2020, 05:30:10 pm »
The absolute best way to convert now is to fit a BLDC kit. They cost about £150 all in and the motors pack a real punch, 1 hp into a 70mm diameter, 100mm long motor. They also have a huge advantage in that with the feedback the controller ups the power if you slow the motor down.
Offline Yansi
  • STM32, STM8, AVR, 8051
« Reply #5 on: June 12, 2020, 05:38:36 pm »
Exactly same you can do with the SCR control, as is often already done in these products.
« Reply #6 on: June 13, 2020, 06:48:29 pm »
Well in the absence of any opinions I had to suck it and see. It doesn't work. No pops or bangs or other bad goings on, no blown components jsut no output.
I guess I am waiting for the Chinese to deliver.
Online jpanhalt
« Reply #7 on: June 13, 2020, 09:09:14 pm »
SCR's are cheap.  Why go China when you can go closer to home and get real stuff?
« Reply #8 on: June 18, 2020, 11:08:55 am »
Well mostly because the stuff you buy here came from China anyway, costs five times as much and has nowhere near as good a warranty if anything goes wrong.
« Reply #9 on: June 24, 2020, 10:49:42 pm »
Well, got the bits, put them in, still no worky. :)
Op-Amp gone, replaced and all working now but no proof that my first idea wouldn't work.
