Author Topic: Brymen BM257s DC volts + Temperature malfunction  (Read 697 times)
Offline pazuwuTopic starter
« on: August 22, 2022, 09:56:54 am »
I've got a BM257s which started acting up recently.
More exactly, when measuring temperature it displays a whacky value at room temperature, e.g. -149C. The temperature probe works ok with another multimeter.
The second symptom I noticed a while after is filmed here: https://www.youtube.com/shorts/501oxSP0ymo.
When selecting the DC volts range, without probes inserted, the display toggles between -3.000V and 0.000V. When connecting the probes, the multimeter keeps seeking a value ad infinitum, without actually displaying anything. And it doesn't show anything when connected to a battery either.
Auto LoZ seems to have the same issue.
Other functions seem unaffected.
Normally, I'd send it in for repairs, but I haven't been able to locate someone who can do this in my country. I'll open the unit up and check everything I can think of, but since I'm pretty noob with electronics, I don't expect to figure out the problem myself.
So I could use some hints about what could be wrong, maybe someone has a service manual too...?
Thanks!
Edit: added some hi-res photos of the board https://drive.google.com/drive/folders/1a2uad6Ypdre2sfcD8KpZAJaUS_igxlNU?usp=sharing
Edit 2: came across a video of Dave's  with another Brymen multimeter with a somewhat similar problem. Guess it's not trivial to fix such a thing.
Edit 3: seems mine works on the DC volts if i manually force the range. Auto range seems to be the issue.
« Last Edit: August 22, 2022, 05:55:02 pm by pazuwu »
Offline aduecho
Re: Brymen BM257s DC volts + Temperature malfunction
« Reply #1 on: August 23, 2022, 08:13:23 pm »
it seems not the HW issue, but the SW, the calibration data in the EEPROM seems lost or corrupt...
