So this is my second SKR board I have killed... was doing somethign that required rewiring, and while looking at the board and a online schematic, I got turned around and reversed the voltage polarity. Not sure how I manage it, but doesn't help that SKR keeps swapping which is positive and which is ground on each board,, I double check it, and somehow, I am still wrong each time
I plug it in, and dead board instantly, just refuses to boot up.
So, this time I decided to try to fix the board as I can't buy a replacement til end of month. I found out that everything on 3.3v is shorted to ground, all the caps, resistors, and obviously power pins. I assumed it was the 1117 3.3 voltage regulator, as those tend to die easily when you reverse the voltage polarity. I took off the regulator, and still, same issue. So, it has to be a different component, though not really all that much on 3.3v, other than the processor, which I don't think is the cause, but could be wrong.
I tried finding the short by checking for heat, but my FLIR multimeter died over a year ago, and no flux on hand. I tried using alcohol, but it all evaporated at the same rate off several chips. No canned air either
I doubt it is a cap also, but guess it could be. I was wondering if anyone has experienced this before, or might be able to pint at a component that is the most likely culprit?
I have attached what I could find. I haven't been able to trave the exact circuit, but all 3.3v pins are shorted, the 1117 3.3 output pin is shorted to ground, and the capacitors nearby seem to be shorted also. The 100 resistors at the stepper drivers are also shorted.
The picture of the board has red dots on every short to ground I found, not sure i got them all, and some could be intentional I suppose.
Thanks for any help.
