Hi, everyone. Ten days ago, the board of an old metal bender failed, it refused to turn on. I extracted the pcb and started checking components. I founded a p-mosfter and a tvs diode shorted, replace it and the machine started again. The repair lasted 10 days, (each day the machine has been on for 8 hours. Everything seemed to be going well); until Today, the machine failed to start, again the same components shorted.
Let’s me try to explain the schematic and the problem.
The section to be repaired is the power supply section, it is a buck converter, it converts 24vdc to 5vdc and 12 vdc. The busk converter is based on the LTC1267CG-ADJ5, the shorted components are
1) the p-mosfet (originally it was 10P03L, replaced by me with AOD417)
2) a TVS diode marked “DX” from ST Component (placed between the 12vdc output and ground, it is a tvs diode with 14,5v threshold)
Output voltages seem to be perfect; output capacitor seems to be ok (checked only the capacity). No other components seem to be shorted or bad.
What can I check? What can cause these two components to fail?
For now, I re-replaced these two components, I put a 24vdc power supply exclusively to power this board, added a proper fuse (before, a wrong “size” fuse was used)
I hope I explained it well and sorry for my bad English. About my electronic knowledge, I’m an automation engineer, for hobby I like to repair electronic boards.
Hope I can receive some useful tips
