Have same mixer, had same fault only the +12v reg was fine. Replaced D7 and everything ok. Cheers.
- Update, intermittently power fail, USB disconnects. Replaced both 7812, 7912 regs and both D3 & D7, now operates ok but then again shuts down after far greater time, up to an hour, spikes audio but remains powered up.
Voltages to main control board 12v, -12v & 32v
Mixer is only just out of warranty and barely used. Disappointing A&H.
