Hey guys, I bought it on eBay with my fortune. And it didn't work
I received a flooded motherboard and some less damaged peripherals. After washing in alcohol
The board is in good condition, the tracks were not damaged.
But the 3V battery on the board was completely dead.
When I connect it to a Windows 10 PC, i see a new "SE Blank SENNA" device with the impossibility of installing drivers.
The board loads take
~5 0,2 seconds. This can be seen from the change in current consumption. After 2-3 minutes, looks like the board goes into reboot cycle (when USB powered).
Using an oscilloscope, I see that the RTC and MCIMX257
https://www.nxp.com/docs/en/reference-manual/IMX25RM.pdf are working, and there are attempts to boot from the bootloader IC TC58BVG1S3HTA00
https://www.mouser.com/datasheet/2/1034/tosc_s_a0007398910_1-2295726.pdfBut Altera Cyclone IV,
1Gb DDR RAM W94AD6KB
https://www.winbond.com/resource-files/w94adxkb_datasheet_pkg_a01-005_20141002.pdf and his DDR RAM IC IS43LR32800G-6BL
https://www.issi.com/WW/pdf/43-46LR32800G.pdfremain without power.
Who knows the POST procedure for it? boot up procedure?
There is DA9021
https://pdf1.alldatasheet.com/datasheet-pdf/download/1010316/DIALOG/DA9021.htmlSystem PMIC with high efficiency USB power manager
General description from PDF:
The DA9021 is a highly integrated PMIC subsystem with supply domains to support a wide
range of application processors, associated peripherals, and user interface functions. Combining a
switched-mode USB compatible charger, full power-path management, three bucks, five linear
regulators and support for multiple sleep modes..
Some secondary power line's of it is 0V, like a VDD MEM line??
How can i check bootloader IC content? MCIMX257 make only two short attempts to access for it.
