Repairing a group of JBL Eon speakers from an installation in a gym, all three units failed after a power outage. The speakers have been powered on continuously for three and a half years, playing low level background music - an easy life for a PA speaker - you might think. No touring, no band / DJ thrashing.
The full range cabinets needed a full power supply / amp board recap (most of the electrolytic caps had dried out, bulged and a couple had blown the tops off) - Both of these now repaired. Scan with a thermal camera showed the reason for the cap failure - the output filter chokes run at 70 ish degrees at idle, and the caps are all mechanically and thermally bonded to one another and the hot inductors with silicone.
The sub had had a flash over in one area, under some type of other adhesive - I've seen another picture online of this module and it is black in colour normally. Black and crispy with a clear liquid residue around the edges in this case.
Under the glue on one side are the resistor divider chains for the SMPS control IC, for HV bus sense from the bulk filter caps.
Also a sense network from the incoming mains phase, which is a power fail fast shut down for the power supply (Class D amplifiers can go unstable as the supplies go down) comprised of a RS1K diode, 3 x 470K resistors in series and a few other components. (Note - this network turned out to be the startup supply for the L6599AD on closer inspection)
Under the microscope I could see C74 had cracked and emitted smoke (shorted) - a noise suppression cap on pin 7 of the L6599AD to ground.
- Line sensing input. The pin is to be connected to the high-voltage input bus
with a resistor divider to perform either AC or DC (in systems with PFC)
brownout protection. A voltage below 1.24 V shuts down (not latched) the
IC, lowers its consumption and discharges the soft-start capacitor. IC
operation is re-enabled (soft-started) as the voltage exceeds 1.24 V. The
comparator is provided with current hysteresis: an internal 13 μA current
generator is ON as long as the voltage applied at the pin is below 1.24 V
and is OFF if this value is exceeded. Bypass the pin with a capacitor to
GND to reduce noise pick-up. The voltage on the pin is top-limited by an
internal Zener. Activating the Zener causes the IC to shut down (not
latched). Bias the pin between 1.24 and 6 V if the function is not used.
Looking at the the clear liquid residue around the failure point, I initially thought that it was electrolyte from the 4 bulk filter caps which are next to it, but removal and inspection of the caps showed no sign of leakage - actually they were the few electrolytics in this speaker set which still met spec for ESR and capacitance. Replaced them regardless with some 10,000 hour Nichicons for future reliability. The liquid appears to be from heat decomposition of the black adhesive - a process which made it conductive in a particularly bad place to have conductive residue.
The two switching Mosfets test OK out of circuit - I replaced the L6599A as it would likely be damaged from the flash over to its sense inputs.
The RS1K diode D20 in the mains sense network was shorted, also C74 on the line input to the IC, and diode D25 also shorted - a MELF package with a green stripe, I believe to be a zener diode. A couple of blown thin tracks have been repaired. The resistors in the divider chains have all been replaced as they were looking a bit charred.
Theoretically when I replace C74 (MLCC, value and voltage unknown) and diode D25 (glass, melf, green stripe, presumably zener diode, voltage unknown) it should be back in working order. All other passives were tested in circuit while the L6599 was removed.
I will replace the main switching mosfets as well (TSC 60NB190) in case they were stressed by the failure. Have them on order from Digikey.
I haven't had any luck finding a schematic for this amp module online (a lot of earlier EON schematics, but completely different power supplies)
Hopefully someone out there can assist with these component values. I'll draw out the line sense network when I get a chance if anyone is interested.
Conclusion - JBL Eon 612 / 618S product is not suited to be powered on 24/7 in an installation situation.
