Here's some more information I've gathered about the voltage dropping (for me @11Vdc).
First of all, it is wise to see which circuit board you have, which version number.
There have been some changes to newer versions from that diagram posted here.
The most important thing in this is the adjustment of 7.5 V and the Ref voltage of pin 16 is omitted and instead a second TL431S with a ref voltage of 5V on the potentiometers etc. The problem I found here is that the ref (2,5V) of U7 (2nd TL431S) is not stable. I solved this by placing an RC over R80 (1K and 100nF). This seems to work. Also check/replace R59 2.0K.
I also adjusted the diagram a bit for my circuit board LW-305D-1 Rev 20191108.
This could help some people.
![Permanent CC and no output [Longwei K3010D]](https://www.eevblog.com/forum/index.php?PHPSESSID=0veuf340aviunitib9r24amnea&action=dlattach;topic=215794.0;attach=1790246;image)
