Author Topic: BWD 539B CRO  (Read 792 times)
Offline Loco1960Topic starter
BWD 539B CRO
« on: March 13, 2020, 01:03:27 am »
I have one of these old beauties but it has a problem, seems no horizontal timebase. The tube appears fine and has a single dot, focussable and movable in X and Y directions. Anyone experienced at fixing these?
Offline james_s
Re: BWD 539B CRO
« Reply #1 on: March 13, 2020, 01:15:32 am »
Are you sure you are using it correctly? I've seen people have this symptom and it turns out they have the scope set in XY mode.
Offline tautech
Re: BWD 539B CRO
« Reply #2 on: March 13, 2020, 01:32:20 am »
Welcome to the forum.
Service manual if you don't already have one and for those playing along at home:
https://www.kevinchant.com/uploads/7/1/0/8/7108231/539b.pdf
The following users thanked this post: Loco1960
Offline vk6zgo
Re: BWD 539B CRO
« Reply #3 on: March 13, 2020, 05:13:12 am »
Have you checked that ir works on X-Y?
A common thing with some BWDs is the loss of internal triggering, which is because  they source their trigger from the output to the horizontal plates, via a high value resistive voltage divider.
The larger of the two resistors in the dividers goes high, reducing the trigger signal below the threshold.
Do you get a "free running" display in "auto"?.
If so, & you can control the sweep rate with the time/div control, try usiing an ecternal trigger signal.
If it now triggers, the fault is as referred to above.
Re: BWD 539B CRO
« Reply #4 on: March 13, 2020, 08:26:33 am »
 I misread the button positions in/out and indeed had it on X-Y
