Author Topic: BWD cro  (Read 699 times)
Offline LuciplaTopic starter
BWD cro
« on: April 23, 2019, 03:40:19 am »
Hi all
Thanks you
I am restoring a old BWD 835 cro and it keep blowing the 10 nano cap in the main supply before the rectifying diodes , anyone have any idea about this problem ?
Kind regards
Lucipla
« Last Edit: April 23, 2019, 07:28:37 am by Lucipla »
Re: BWD cro
« Reply #1 on: April 23, 2019, 09:45:42 am »
Welcome to the forum.
C604 should be a mains rated Y class cap.
As it's across the L and N it needs be 275VAC rated at least.
Google 'x and y rated caps' for further info.
However it's just for mains suppression and it's not necessary for operation. Value is not critical and you can get Y class caps from Jaycar when you're next there.
In the meanwhile just use the scope.
« Last Edit: April 23, 2019, 10:26:12 am by tautech »
