Hi, i got a made in china UV sterilizer and it was working fine till a recent power trip in my place... after which it has stopped working...
Took it a part and found that the high frequency transformer is not functioning but am unsure if i am right on that.
The transformer has 4 input (2 power, 2 gnd) and 2 output (12v and gnd), i have measured the output coil is working at 0.1ohms but when connected.. then is no voltage across as such the control circuit has to power to function...
So would like to ask for help in checking of high freq transformer...
Thanks.. it needed, i can post the model and pic of what have been checked..
