HI everyone,
I am trying to fix a Marantz SR-810 receiver. The receiver apart from other issues also has a blown diode which was so bad it was no longer possible to identify. Also not able to find a service manual for the SR-810. However I did find a service manual for an SR-1000 and it seems to be very similar build looking at pictures of the internals. The service manual suggests that the zener diode that is blown in my unit is a BZ-140 which google tells me is a 14V 1W zener diode.
What would be a suitable replacement as this diode is no longer manufactured?
From what I know about diodes, it will have to be 14V and at least 1W. From reading suggestion is that I should not try and replace it with a higher Wattage diode and stick to a 1W spec. Any suggestions for a modern readily available alternative? An NTE144A has been suggested in another forum but that one is also not a diode easy to find.
Here is the schematic, with the diode highlighted in yellow.
Cheers guys and ladies.
