Hello all! I thought I might see if anyone on the forum has successfully repaired one of these units. I understand this is a fairly common problem with these scopes and have read a few entries here regarding this problem but I don't think I've seen any where the scope was brought back to life. I've got a TDS 3052B that is stuck at splash screen. No relay click, nothing, just splash screen. Inside there are no blown components, power supply is working well. i thought I might take a chance and pull out the timekeeping ram to replace but that would be a shot in the dark. Is there a way to test the ds1742 to see if the battery is indeed dead? Date code on mine is 2006 so it could certainly be older but still could be dead. Any and all ideas are welcome, Thanks!!
