Translated:
I need to know if this will have audio cable M01 a failure it does not work because the install from the Headset Bluedio T4hacia the music player. The cable has a "C" type male and the other end terminal 3.5 mm, have reviewed continuity between pins of the terminal C and 3.5 mm vvariadas showing resistance between them is correct or there that new replacement ?.
Thanks in advance for possible help.
Foro de ingles
This is an english forum
