In a pinch, you can use a known voltage source (or any voltage source and an accurate multimeter) for amplitude scale calibration. For a rough timebase calibration, generate a tone from a computer sound card, 10kHz for instance. It should be accurate within less than 1Hz, more than good enough for getting an old analog scope in the ballpark anyways.
