I have an issue while testing the California Instruments 3091LD. It pops the 222 error message and not allow to input info to test. Its message is "Parameter data send with command is out of range."
According to manual solution, 222 errors are "Check mode or range settings."
what are the corrects to setting. I do not have Lab View to test. I do it manually.
Thank you,
