Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Water damaged CRT TV
« previous
next »
Print
Search
Pages:
Prev
1
2
3
All
Go Down
Author
Topic: Water damaged CRT TV (Read 15786 times)
stj
Super Contributor
Country:
Re: Water damaged CRT TV
Reply #50 on:
August 07, 2016, 03:52:45 pm »
a trick i used to use is swapping 2 colours over at the point of origin - in this case the rgb matrix decoder - to see if the colour on the screen changes.
Logged
Srbel
Frequent Contributor
Country:
Electronics engineer
Reply #51 on:
August 07, 2016, 04:04:12 pm »
Ah, the connector is asymmetrical, so it only fits in one orientation.
The problem is that I only get something on the screen if those colour signals are disconnected. When I plug them back in, I get nothing on the screen. :/
Logged
stj
Super Contributor
Country:
Reply #52 on:
August 07, 2016, 06:00:49 pm »
check any white or gray resistors on the rgb pcb, philips used resistors as fuses.
Logged
Srbel
Country:
Reply #53 on:
August 07, 2016, 06:07:20 pm »
There is one, and it is fine. Measures 15 ohms.
Logged
Srbel
Country:
Reply #54 on:
August 09, 2016, 10:42:55 am »
Any more ideas?
Logged
Srbel
Country:
Reply #55 on:
August 11, 2016, 07:10:58 am »
I am stuck. I don't know what board is at fault. I don't know how CRT should behave, what signals it should get and so on. And this is the last day I can use for repair. After this, I have no more time for it.
Logged
stj
Super Contributor
Country:
Reply #56 on:
August 11, 2016, 02:02:51 pm »
check all the psu voltages against the schematic.
if you have HT then the problem is in the decoding or gun-drive area.
Logged
Srbel
Country:
Reply #57 on:
August 11, 2016, 02:43:01 pm »
There are hundreds of voltages in schematics. They are not accessible (no test points). I would need to hunt down a certain capacitors on the PCB and then solder a wire on the bottom side, then get everything back in place in order to measure it. I dont want to poke around with a few 10s of KV present.
I don't know what HT stands for.
Thanks for help, but time is up. So, I have to give up.
Logged
MosherIV
Super Contributor
Country:
Reply #58 on:
August 11, 2016, 03:08:50 pm »
High Tension.
Tension is another term used for very high voltages.
Logged
Print
Search
Pages:
Prev
1
2
3
All
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
