I would like to share with you my latest extreme repair and ask for some help as the unit does have some temperamental issues that I am struggling to diagnose.
I purchased the unit as not working for an occasional price with a view of restoring it. Unit was activating protection mode just after start. I found some corroded resistors and links that were in contact with adhesive. I replaced them and cleaned the PCB. I inspected transistors and found no issues with them. Once I started checking further I found that there was no voltage from the toroidal transformer. I measured the primary winding and confirmed that the thermal fuse was blown. Finding another one was quite hard and not worth spending the money. At that stage I decided to take a risk and carefully unwind the transformer and replace the fuse. Nothing to lose.
I carefully marked everything and coiled each winding. I removed as much as necessary, and I cut through insulation to get to the fuse. After soldering new fuse in place I pushed it back in and injected epoxy resin with syringe. Kapton tape was used to encapsulate resin. Once cured, I used few layers of Kapton tape for extra protection. At that stage in was time for tedious task of rewinding everything. I tried my best to straighten the wire ensuring it is not damaged at any stage and keep everything tight at the same time. To be on the safe side, I used a multimeter to check from time to time. Final result was satisfactory. I carefully installed it back in place and measured output voltage before connecting it to preamp board. All readings been fine and I felt comfortable to connect it fully. Unit at this stage was alive. I left the unit up and running for a few hours and the transformer held up nicely.
At this moment I am struggling with some temperamental issue as occasionally the right channel fades out or is not playing at all. I suspected potentiometer as changing sound level can cure the problem. I measured resistance and couldn't find any issue. I opened it and the condition was almost like new. I can't find any dry joints and moving components/cables does not have any effect. At this stage I am a bit puzzled. Any ideas are more than welcome. Service manual in the attachment.
