Author Topic: Camera SoC identification  (Read 904 times)
Offline dc101Topic starter
« on: May 28, 2021, 07:31:31 pm »
Looking for some help trying to identify a chip with part number CLM9020 on it. This board is the main pcb of an Axon Flex body worn camera. I believe the chip is a dedicated Camera SoC similar to those made by Ambarella and HiSilicon, but I haven't had any luck searching for the vendor. The CSR chip on the right is some sort of bluetooth chip.
Offline josh132
  • OSCILLOSCOPE
Re: Camera SoC identification
« Reply #1 on: May 28, 2021, 08:29:43 pm »
Im not getting results for CLM9020 either, getting better results when trying LM9020. C in CLM maybe a branding thing. Not familiar with the logo on the ship.
bu du bu nu
Offline amyk
« Reply #2 on: May 29, 2021, 03:21:54 am »
http://www.aoelectronics.com/en/manufacturers-detail.php?tnid=156
Established in 1998, Core Logic, with an expertise in mobile multimedia SoC development, has concentrated efforts on developing SoC products and providing services for the IT industry, and taken a leading role in the establishment of the fabless industry model in korea.
CLM9721   19MM X 19MM, 620PIN, 0.65PITCH
CLM9722   15MM X 15MM, 450PIN, 0.65PITCH
CLM5530   15MM X 15MM, 416PIN, 0.65PITCH
CLM7700   15MM X 15MM, 335PIN, 0.65PITCH
CLM7600   17X17MM 0.80MM PITCH, 400PIN
CLM5520F   15MM X 15MM, 452PIN, 0.65PITCH
CLM5520F2   17X17MM 0.80MM PITCH, 400PIN
CLG7700   15MM X 15MM, 335PIN, 0.65PITCH
CL90xx   ARM926E RISC CORE
CLM65xx   ARM926E RISC CORE
CLM90xx   ARM926E RISC CORE
CLM5510D   10X10 144PIN 0.8BALL FBGA (MDDR 16MB STACKED)
CLM5510   10X10 196PIN 0.65BALL FBGA (NO STACK)
CLI2000   8X8MM 0.50MM PITCH, 180PIN
The site (and company) appears to be gone, but fortunately the CLM90xx' product brief appears to have survived in the web archive: http://web.archive.org/web/20151216161748/http://www.corelogic.co.kr/down_pb/090916_JADE_PB_(5.0,2.0).pdf (my happiness upon seeing it was several MB and suggestive of a full datasheet was immediately erased upon opening it...)
Here's a slightly earlier revision of your BlueTooth: https://cdn.datasheetspdf.com/pdf-down/B/C/5/BC57G687C-CSR.pdf
The following users thanked this post: dc101, fzabkar
« Reply #3 on: May 29, 2021, 05:15:27 am »
Dang, that's some ninja google skills right there! Thank you!
