Author Topic: Oscilloscope Gould OS300 horizontal trace problem  (Read 779 times)
Offline jpwmTopic starter
« on: September 21, 2019, 07:50:22 am »
I recently purchased this oscilloscope on Ebay, unfortunately the seller packed it badly so that some plastic parts of the case broke and the CRT came loose. I pulled it back into position and fastened it with cable ties. Unfortunately the horizontal axis doesn't work properly anymore.
The trace of both channels can only be moved horizontally in an area between the left edge and the middle. Both traces can be moved vertically over the complete height up to outside the CRT.
I have the manual for the oscilloscope, but so far I have only worked with considerably newer devices and therefore I can't really understand which setting could solve this problem. Online I found some similar questions, but there were never satisfactory answers. I would be happy if anyone had an idea what the problem is.
(I also uploaded a video of the problem: https://streamable.com/z8c7c)
Offline shakalnokturn
Re: Oscilloscope Gould OS300 horizontal trace problem
« Reply #1 on: September 22, 2019, 09:03:50 am »
If CRT came loose first look for broken wires / connections to the X plates. (Between CRT and PCB)
Other than that the X output stage is symmetrical (one output does the opposite to the other) if you have damage on 1/2 you'll lack X amplitude and offset on one side.
The following users thanked this post: jpwm
Offline jdragoset
« Reply #2 on: September 22, 2019, 04:28:56 pm »
Had a similar problem in the vertical channels on a tek 2215.
Turned out to be an open resistor in one side of the vertical output stage.
Check components on both sides of the horizontal output stage.
