Author Topic: Can anybody help me identify this part? (re: slide potentiometer; "B103")  (Read 428 times)
Offline sofakngTopic starter
I'm trying to repair a flight stick (joystick) for the Xbox and this slide potentiometer is broken. I disassembled it and the contacts (?) on the slide (?) are bent. I tried to bend them back but it doesn't seem to work.
  • The slider is 60mm x 9mm x 6mm and has 3 contacts (2 on one side and 1 on the other)
  • "B103" is written on the underside
  • The other working potentiometer shows 6 Ohm - 5.2K Ohm.
Can anybody help me find this? I've searched Mouser/Digikey and can't find a match.
Offline fzabkar
"103" = 10Kohm
"B" = linear taper
Online Harry_22
Hi!
Try XVJ45 on Aliexpress
Thanks very much!!
