Author Topic: Can anyone identify this chip  (Read 7007 times)
Offline tk1Topic starter
« on: July 04, 2015, 09:47:28 am »
Is anyone able to identify this chip and a proper replacement?
I am trying to repair an Asus laptop motherboard.
Any help is appreciated
Thank you
Offline 0xdeadbeef
Re: Can anyone identify this chip
« Reply #1 on: July 04, 2015, 09:57:27 am »
I would assume it's some kind of TVS diode array.
Offline poorchava
  • Troll Cave Electronics!
« Reply #2 on: July 04, 2015, 11:22:27 am »
Might be hard to find a generic replacement, to as TVS arrays are often targeted at specific applications. For example CDSOT23-720 is specially targeted for RS-485 interfaces.
Sent from my HTC One M8s using Tapatalk
Offline dfmischler
« Reply #3 on: July 04, 2015, 12:12:39 pm »
If you can find the service manual for that board (ASUS K55VD REV 3.0: it probably exists), it should give you a part number.  Good luck.
Offline 0xdeadbeef
« Reply #4 on: July 04, 2015, 12:15:17 pm »
Googling for "k55vd asus pcb" brings up interesting pictures from a polish forum:
The connector is described as power jumper there. They couldn't identify the chip either.
I fear that looking for a SOT23-6 TVS diode array with the marking "21" could be somewhat difficult.
Offline Deathwish
  • Country: wales
« Reply #5 on: July 04, 2015, 03:29:34 pm »
Electrons are typically male, always looking for any hole to get into.
trying to strangle someone who talks out of their rectal cavity will fail, they can still breath.
God hates North Wales, he has put my home address on the blacklist of all couriers with instructions to divert all parcels.
Offline ez24
  • L.D.A.
« Reply #6 on: July 04, 2015, 05:28:31 pm »
Any chance it could be this
http://www.diodes.com/datasheets/BAS21TW.pdf
if you do not think the last marking is a "t"  but a vertical marking YM  (year month)
look at the "marking" section
Offline Deathwish
  • Country: wales
« Reply #7 on: July 04, 2015, 06:26:26 pm »
The part i posted is directly taken from the asus boardview diagram with part numbers etc.
« Reply #8 on: July 04, 2015, 07:17:00 pm »
Thank you all so very much. Thank you so much Deathwish, huge help, hopefully now I locate the proper replacement.  :D
Offline Deathwish
  • Country: wales
« Reply #9 on: July 04, 2015, 08:55:57 pm »
If you go here and join up, you can then download the files yourself to look at.
http://badcaps.net/forum/showthread.php?t=45306
« Reply #10 on: July 04, 2015, 09:02:24 pm »
cool, thanks
also, I just ordered the chip... actually 25 of them to make it worth while with shipping and all... lol
Offline Deathwish
  • Country: wales
« Reply #11 on: July 04, 2015, 09:09:20 pm »
25 !,oh well you can blow a few then, send us pics of the magic smoke....
If you download those files and run up boardview it will be in chinese , go to the top of the window and click the third from the right, then the second one down and change the language to English. then press CTRL+F10 to load the file in ok.
you will need to load the file named K55VD 3.1,60-N8DMB1800-B03.FZ into the sub directory calle fab in the main programme directory then when pressed ctrl+f10 to load it paste the name minus the extension in the pop up box and then ok. you then need to use the RefDes box to drop down to the part you are looking for by its board designation. it will tell you what part it is in that.
« Last Edit: July 04, 2015, 09:16:07 pm by Deathwish »
« Reply #12 on: July 04, 2015, 09:12:37 pm »
ok cool
thank you again for your help, hopefully the motherboard will be functional after the repair (crosses fingers) lol
Offline Deathwish
  • Country: wales
« Reply #13 on: July 04, 2015, 09:15:30 pm »
i just edited the prior post to explain how to load it up
« Reply #14 on: July 04, 2015, 09:17:18 pm »
ok thanks
Offline mcinque
  • I know that I know nothing
« Reply #15 on: July 04, 2015, 09:19:58 pm »
Well played Deathwish! :-+
@tk1: I guess that if it's an ESD protection like Deathwish posted, the mainboard should work even with that part blown (unless it's shorted?), don't you?
What are the symptoms other than that component blown? I guess that to damage that ESD protection in such way, you need just a lot more energy than ESD, so maybe there is something that could be damaged other than that component. What do you think about this?
« Last Edit: July 04, 2015, 09:29:03 pm by mcinque »
